Wiring - Hampton Bay Ventilation Fan
Old 10-26-14, 10:09 AM
Hello - I am replacing an old light/ventilation fan with a Hampton Bay 316-622 model. I want to confirm my wiring setup - as this "quick connect" confuses me a little - even though I think I have an idea how to use it.
I have a single switch that runs 2 wires to the existing fan - white & yellow. The wiring of this new fan is where I am needing help. I have a black & white wire each saying "fan connection", 2 whites - one labeled "night light connection" & the other "light connection", 1 red labeled "night light", and 1 blue "light kit connection". Again, where I am thrown is the "quick connect"... I'd rather strip / use wire nuts.
My thinking is I use my white house wire & wrap all 3 whites around it, but I'm not sure what my yellow wire connects to.... I think it would go to the black "fan connection" and blue "light kit", and then the red "night light" gets covered w/ a wire nut.
Appreciate any help... thanks!
Old 10-26-14, 10:16 AM
Received 4,156 Upvotes on 3,732 Posts
Welcome to the forums.
Your wiring as you have described will work correctly. The fan and light will come on together.
Old 10-26-14, 10:19 AM
ray2047's Avatar
If this is conduit you may want to fish more wires so each function can have its own switch. Your simplex switch could be replaced with a triplex switch so no new box needed*.
*Box fill permitting.
Old 10-27-14, 05:00 AM
Thanks to both answers, much appreciated!
