Motion Sensor blowing bulbs
Old 11-06-14, 10:13 AM
E
I have a Heath-Zenith motion sensor on my garage. It has two bulbs. recently, one side keeps blowing bulbs. can't figure out whats going on. Any ideas?
Thanks John
Old 11-06-14, 11:54 AM
P
Received 1,765 Upvotes on 1,578 Posts
First I would suspect the bulbs you are using. Try getting some quality, brand name bulbs rated for 130 volts.
Old 11-06-14, 01:19 PM
Received 74 Upvotes on 69 Posts
If the fixture uses a standard screw base lamp try pulling the center contact (With the power off of-course!) to make the bulbs make better contact with the socket as a loose connection can arc and that can cause the bulb to not last as long as it should
