Go Back  DoItYourself.com Community Forums > Electrical, AC & DC. Electronic Equipment and Computers > Lighting, Light Fixtures, Ceiling and Exhaust Fans
Reload this Page >
Is there any way to spruce up a porcelain lighting fixture without replacing it?
Old 11-16-14, 08:09 PM
N
Received 1 Upvote on 1 Post
I'm doing my basement on the cheap and rather than change all the light fixtures, is there a way I can add or attach a bowl-like contraption, like an aluminum cowl onto the porcelain fixture...or, if I have to remove the porcelain fixture is there another fixture I can wire up as easily as a porcelain fixture to the electrical box? I just want to give it a slightly more enhanced look without necessarily replacing the fixtures with recessed canned lighting, just add like an aluminum cowl or bowl to go over the bulb. Thanks in advance.
Old 11-16-14, 08:21 PM
ray2047's Avatar
Clip on ceiling lamp/bulb shades. Example: https://www.lampshadeshop.com/lampshades2be.htm
N
I guess the other name for what I was thinking of was shades or aluminum shades when I was referring to bowls up above, lol. Similar to these on ebay, but cheaper: 5 Vtg 16" Porcelain Westinghouse White Barn Industrial Warehouse Light Lot | eBay
Old 11-16-14, 08:42 PM
N
Thanks for the tip ray2047!
Old 11-18-14, 08:20 PM
Andrew's Avatar
Received 14 Upvotes on 10 Posts
Here you go. These screw into the existing sockets, and have a reflector like the industrial style from ebay...
Designers Edge L-1710 12-Inch Indoor One-Light Downward Farm Light Fixture, Powder Coated - Flood Lighting - Amazon.com
Andy
Old 11-19-14, 06:10 AM
Received 1,262 Upvotes on 1,203 Posts
Last time I looked, you could get fixtures with glass shades at the big box stores and get change back from a $5 bill.
Old 11-19-14, 06:12 AM
Eh, looks like it's been a while but there were still fixtures under $10. Something like this is what I used to be able to find for $4: Thomas Lighting 2-Light Semi-Flush White Ceiling Fixture-SL123 at The Home Depot
