? possiblity of exhange round light to differnt style no rewire?
Old 11-20-14, 06:24 AM
B
We have 10 ft high ceilings and in our hallway we have one round light with glass globe and metal ring. I believe it has 2 light bulbs in it. We are seniors both low vision so this is not enough light but hoping that maybe would not have to rewire but maybe put a kit into where that round light is. If such a thing exists where can we get it at the best price? Thanks in advance for any input you may have.
Old 11-20-14, 06:31 AM
Received 1,248 Upvotes on 1,192 Posts
Welcome to the forums.
Sorry, not following but I think you're asking whether you could replace this fixture with one which throws more light and the answer is you certainly can.
With a 10' ceiling I'd be inclined to put up a ceiling fan with four bulb light kit.
Old 11-20-14, 03:31 PM
Andrew's Avatar
Received 14 Upvotes on 10 Posts
You can install some compact fluorescent bulbs in there, perhaps 100W equivalent or higher. This should provide quite a bit of light, without the need to change the fixture.
Andy
Old 11-21-14, 09:03 AM
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
You maybe better installing a pendant style fixture which would hang down from the ceiling a foot or two,can you send a pic of the area of concern? Also check the big box stores to see what is available,check at local lighting stores also although they maybe more expensive they will have a much better assortment,be careful of CFL's in enclosed fixtures if they are not rated.
Geo
