Heat light in bathroom
Old 11-20-14, 06:17 PM
H
Received 3 Upvotes on 3 Posts
I have one of those red bulb heat lights in my shower. I hate it, it was there when we moved in. Can I just put a different bulb in there or do I need to change the entire fixture?
If I do need to change the fixture is the wiring the same as a normal light or is that different as well?
Thanks!
Old 11-20-14, 06:23 PM
ray2047's Avatar
If it is a medium base bulb a regular bulb will work but you may need to use a bulb extender because some heat lamp bulb holders are deeper then the neck of a regular bulb.
Old 11-21-14, 11:05 AM
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
You could install an R40 style flood in there or there is a clear style infra lamp you could install if just the color of the lamp is the problem.
Geo
Old 11-21-14, 05:48 PM
H
awesome thank you! didn't know what was going to be involved, and yea..not a fan of the red AT ALL haha
