New Light Fixture and Switch problem
Old 11-25-14, 05:51 AM
W
Replaced a motion sensor light after the sensor failed on the old one. Prior to replacement, the indoor switch for the light worked fine. New fixture has the same 3 wires (white/black/green) as old. Replaced the fixture and now the switch has no control over the light. The switch is mid-stream on the circuit. The wiring from the switch is black/white/red/ground. The wiring downstream from the light is black/white/ground.....can someone explain why the switch no longer controls the light?
Old 11-25-14, 06:48 AM
ray2047's Avatar
Is this a 3-way switch. It sounds like it. Is the 3-conductor cable the only cable in the switch box? If so and it is a 3-way circuit then the light is fed by the other switch.
Old 11-25-14, 09:04 AM
W
No, it is not a 3 way switch. This is the only switch to the fixture.
Old 11-25-14, 09:56 AM
Handyone's Avatar
The switch has no control over light, but does the light illuminate the way you connected it?
Is there anything downstream from motion light that doesn't work?
Old 11-25-14, 10:48 AM
W
No, the switch doesn't impact the light at all, and yes, the light is fully functional. Nothing downstream is affected in any way.
Old 11-25-14, 11:14 AM
ray2047's Avatar
Ignoring the ground which isn't relevant how do you have 3 wires on the switch?
Old 11-25-14, 11:19 AM
Handyone's Avatar
You'll need to pull out the switch, don't disconnect the wires, just describe what's all in the box and what wires are connected to switch terminals.
