Adding box for wall mounted light
Old 12-08-14, 02:56 PM
R
Hi,
For some odd reason when they did the addition on my house the only light in the "game room" (the one between the garage and the main house) is a CFL hooked to a set of wires coming out of a hole in the drywall (long story, but I wasn't here when the construction was actually done...). I'd like to replace it with a "real" wall mounted light. Since the wall is "finished", i.e. has drywall on it and is painted, I was thinking that some sort of electrical box that can be put into the drywall and will support the light. What's the best way to do this? Or do I need to find some way to add a box and attach it to a stud?
Thanks,
Rob
Old 12-08-14, 03:23 PM
Received 3,897 Upvotes on 3,494 Posts
You could cut in an old work box, either metal or plastic, depending on the weight of the fixture. Ray made a recommendation for a 4" round box. Depending on the fixture base... that would be a better choice.
Old 12-08-14, 05:57 PM
Handyone's Avatar
The old work ceiling boxes are a little harder to install than the wall boxes, cut out is more exacting. You do need the old work ceiling box, but try to find a template for the cut out. Template should be available at the place of purchase, but they are often missing.
Old 12-09-14, 08:54 AM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
A 4" holesaw works very well for the old work ceiling boxes.
