wiring for florescent fixture
Old 12-11-14, 04:12 PM
D
I have to change out a 4 florescent fixture and install a new one. There are 2 red and 2 black wires coming from my ceiling and only a white, a black and a green wire in the fixture. I am absolutely clueless as what to do without burning the house down
Any help would be appreciated
thank you
Old 12-11-14, 04:27 PM
Received 4,101 Upvotes on 3,683 Posts
Are you sure there aren't any more wires ? There should be white wires present.
What colors are connected to what now ?
Old 12-11-14, 04:42 PM
D
There are 2 red from the ceiling that are twisted together and 2 black that are twisted together. When I took out the old balast there were 4 wires coming from each end of the balast box. I went to the hardware store to buy another balast but none had 4 wires from each side coming from the balast so I bought a whole new fixture not realizing it only had but the black, white and green wires.
I am adding this - it is 2 greyish green wires, not black, sorry
No whites
Old 12-11-14, 04:48 PM
chandler's Avatar
Received 10 Upvotes on 9 Posts
As Pete asked, how were they connected on the old fixture? There must be a white set of wires somewhere in the mix. Can you take a picture of the ceiling box with the wires pulled down so we can see them? http://www.doityourself.com/forum/el...your-post.html
Old 12-11-14, 04:49 PM
D
I added to my last reply that there were 2 greyish blue wires not 2 black wires
Old 12-11-14, 04:54 PM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Are there other fixtures on that circuit?,what was connected to the red and black conductors ?can you post some pic's so we can see what is there?
Geo
Old 12-11-14, 04:58 PM
D
Here are the pics
Size:  33.1 KBName:  P1010001.jpg
Old 12-11-14, 05:08 PM
Geochurchi's Avatar
Do you have a volt meter?measure voltage between red and grey you should get 120 volts with the switch on, I would say that the black from the ballast goes to red and white from the ballast goes to the grayish color conductors.
Geo
Old 12-11-14, 05:12 PM
D
thank you. here is one more pic of a fixture about 3 feet from the other one. It isn't florescent but it has the white wireName:  P1010003.jpg
Old 12-11-14, 08:38 PM
Gray is an alternate color for neutral when the system is wired in conduit.
