Lighting question, 14/3 to 14/2.
Old 12-19-14, 08:32 AM
R
I have attached a diagram of my wiring. The 1st light in the series works fine but the 2nd-6th do not. Any help would be great. I have the black wire from my 14/3 going to my outlets that need constant power. Then, for the lights that I want run off of the switch I tapped into the red wire. That worked great until I chained my recessed light together and only the 1st light came on.
Old 12-19-14, 08:45 AM
ray2047's Avatar
Your wiring is correct. Redo your connections at the first light and second light.
Old 12-19-14, 08:47 AM
Received 4,057 Upvotes on 3,640 Posts
Welcome to the forums.
The problem is either at the first light where you do have a working fixture or at the second fixture which is dead.
