Chandelier has two fabric covered yellow wires - which one is hot?
Old 12-21-14, 11:20 AM
D
The yellow fabric on one of the wires is solid yellow, the other is yellow with a black/brown thread interwoven throughout. How do I know which is the hot and which is the neutral wire?
Old 12-21-14, 01:49 PM
chandler's Avatar
Received 11 Upvotes on 10 Posts
With your analog multi meter (~$10), test each wire to ground. Most likely you will see the one with the brown tracer to be the neutral, but no guarantees.
Old 12-21-14, 05:04 PM
pcboss's Avatar
Received 206 Upvotes on 179 Posts
The neutral or white should show continuity with the bulb shell.
Old 12-22-14, 05:28 AM
A
Received 294 Upvotes on 269 Posts
Unscrew all of the bulbs. Test the continuity (meter ohms function) between the loose (unconnected or unhooked) feed wires going into the chandelier stem and the sockets.
