Ballast for UV bulb
Old 12-25-14, 03:08 PM
T
Ballast for UV bulb
I have an Ozone Generator where ballast and bulb are damaged. Looking for replacement parts, I figured the original parts are overprized and I am looking for alternatives.
I found this bulb that seems about the same size. Philips 11250-8 TUV 16W FAM
( BulbConnection.com - Name Brand Replacement Lamps for Less! )
How do I know if a ballast is compatible with this bulb?
I was looking at this model RSN1GPH20120 ( RSN1GPH20120 /BN @ Robertson Direct ) but am not sure if it would work of fry the bulb?
Would appreciate someone telling me if this one works or recommend a suitable alternative.
Also I do not understand why the UV bulbs need special ballasts, but I see there is a special product range for UV bulbs.
Thanks a lot in advance.
Old 12-25-14, 04:08 PM
Received 4,145 Upvotes on 3,722 Posts
Welcome to the forums.
The specs look pretty much similar. UV tubes may have to be kept close to a set operating voltage for maximum performance in it's intended output range.
Old 12-26-14, 04:55 AM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Contact Robertson Customer Support from their Web site.
Geo
Old 12-26-14, 05:19 AM
T
@ Geochurchi:
I tried that first. Sent a message to Robertson on Nov 20th with follow-ups on Dec 8th and 13th. If you’re asking me, their customer support is non-existing.
Thanks for your reply PJmax.
Old 12-26-14, 07:23 AM
Geochurchi's Avatar
Do you have a Mdl number from the old ballast ?
Geo
Old 12-26-14, 08:04 AM
Tolyn Ironhand's Avatar
Received 913 Upvotes on 771 Posts
Looking at the specs of each item it appears that the ballast would work for that bulb.
Old 12-26-14, 01:27 PM
Geochurchi's Avatar
I have a reply from Robertson,hope it helps .
http://www.amazon.com/ROBERTSON-PSM2.../dp/B00JIW11R2
Email from RobertsonI was checking my emails when I noticed your request so I thought I would respond now.
The Robertson PSM2GPH18MVDW (3P20165) is the recommended ballast for your application. It will operate one or two Philips 11250-8 TUV 16W FAM lamps. Please follow the link below for pricing and availability.
Last edited by Geochurchi; 12-26-14 at 01:30 PM. Reason: Added email from Robertson
