LED 5 Watt 120 Volt Wire Gauge
I am installing 4 5 Watt 120 Volt LED lights in a ceiling using an existing switch with 14 gauge going to the lights being replaced. I plan on going to a junction box a short distance from the switch with existing 14 gauge and then go from there to the 4 new lights. If that is acceptable I would like to know the wire gauge from the junction box to the lights (~6'). The only specification noted on the lights is at least 194 degrees F.
Can someone please help me identify appropriate wire for the installation?
I also intend to follow a very similar path for 2 10 Watt 120 Volt LED lights.
