New Kitchen Light Fixture
Old 01-07-15, 06:55 PM
I am currently redoing my kitchen, and that includes new light fixtures. I removed an old fixture and found there were two white wires used to connect it. Any idea how to reconnect to the new fixture? Also, when I tested the wires, there seemed to be no power.
Any ideas?
Old 01-07-15, 08:25 PM
Received 4,116 Upvotes on 3,696 Posts
Welcome to the forums.
Your old light was connected to just those two white wires and the red and blacks were untouched ?
Is that light controlled by a pair of three way switches ?
Old 01-07-15, 08:26 PM
ray2047's Avatar
If the old one worked so should the new one connected the same way.
Was that with the switch on? If you used a non contact tester the result is meaningless.
As to why you have two you have two white wires I suspect a switch loop wired non conventionally. Do you have a black (or red) and white wire on the switch?
Edit: Disregard post if it is a 3-way.
Old 01-07-15, 08:47 PM
It is three way, how does this change things?
Old 01-07-15, 10:15 PM
ray2047's Avatar
Does the new light work when connected?
Old 01-08-15, 01:02 AM
I haven't hooked it up yet
