Replace with Correct Ballast
Old 01-22-15, 03:08 PM
R
Received 4 Upvotes on 4 Posts
Helping out my 98-year-old neighbor who asked if I would replace some light bulbs. Picked em up at Homer but no dice.
The lettering on the old ballast is faded/barely readable, this is all I can discern:
General Electric - 240RS-120-P and 8G1022W
I can't seem to find the correct replacement? Is it obsolete?
The fixture holds 2 lamps that are F30T12CW.
Bulbs are: 30 watt - 36" - T12 - Medium Bi-Pin (G13) Base - 4,100K
I don't know which ballast at Home Depot is the right one?
If anyone knows what the modern day crossover is/which new ballast to buy/install for her? TIA!!
Here's a pic of the old ballast:
Old 01-22-15, 04:42 PM
Received 4,046 Upvotes on 3,630 Posts
240RS-120-P is a GE ballast number. It is still available but not at the depot. You'd have to get it at a lighting showroom or electrical supply or order it online like in the link below.
amazon/GE-97499-GE240RS120-DIY-ProLine-Electronic/dp/B001DT6KU6
Unfortunately, depot lists a replacement ballast but it doesn't specifically say T-12 lamps so I wouldn't try it.
If you converted the fixture to T-8 lamps..... depot does carry that ballast. T-8 lamps will fit the sockets in that fixture. A slight re-wiring of the sockets would be required.
Old 01-22-15, 06:41 PM
R
Thanks Pete.
I really appreciate the advice. I'll check with my local supply house.
Thank you.
