Dimmer for 4 way switch system
Old 01-24-15, 05:41 AM
T
I can't seem to find a diagram for this. I need pictures. I'll try and make the run down of my set up.
14/2 line - 3way switch - 14/3 line - light - 14/3 line - 4way switch - 14/3 line - 3-way dimmer.
I just haven't found any diagrams with this order.
Thanks for your help
Old 01-24-15, 07:04 AM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
The dimmer will need to be a 3 way dimmer installed in place of the 3 way switch ,not in place of the 4 way,instructions should come with the dimmer.
Geo
Old 01-24-15, 07:12 AM
ray2047's Avatar
To simplify things be sure the dimmer does not need a companion switch but will work with a regular 3-way at the other end.
Old 01-24-15, 08:10 AM
Received 4,115 Upvotes on 3,695 Posts
Thanks Ray.... that is most important.
Have you already gotten the dimmer or are you just looking ?
Since you want to install it at the end of the four way system.... you'll need a no-companion required dimmer as well as one that doesn't require a neutral.
Otherwise when I encounter a situation like yours I DO NOT fool around. I install a Lutron dimmer with two companion control dimmers. The lights are dimmable at all three locations. I particularly like the Maestro line. The dimmer is a tad costly.... around $45 and the companions are around $15 each.
Old 01-24-15, 12:46 PM
T
Again I need a diagram of the wiring in the order I described. Everything is installed I just need to know what wire travels, etc. Look at my order....I did not put dimmer in place of 4-way switch...
Old 01-24-15, 12:49 PM
Then we'll need a model number of the three way dimmer you're using as that will affect the wiring.
Old 01-24-15, 03:31 PM
pcboss's Avatar
Received 205 Upvotes on 179 Posts
A three way dimmer connects the same as a regular toggle switch. Pay attention to the wire on the odd colored terminal and make sure it connects to the common on the dimmer.
Old 01-24-15, 09:24 PM
That is not always true...........
Old 01-25-15, 01:06 PM
T
The dimmer is a Lutron contour CTCL-153P(3-way). It is the last in the run. The 4way is 2nd to last. So let me explain again. 3-way switch, light, 4-way switch, and then dimmer(Lutron contour CTCL-153P(3-way switch).
Old 01-25-15, 02:10 PM
ray2047's Avatar
Does power come in at one 3-way and go to the light from the other 3-way or is power in in the same box as the cable to the light?
Old 01-25-15, 03:21 PM
T
This is the order:
14/2 power in to 3-way switch 14/3 line to light 14/3 to 4way switch 14/3 to dimmer 3/way switch(red, black, red/whiteline) end of run.
Old 01-25-15, 04:34 PM
The following should be what you need.
Old 01-25-15, 04:46 PM
T
I will give it a shot tomorrow. Thank you!
