Rigid conduit won't fit in new fan rated box
Old 01-26-15, 08:15 AM
G
Size:  36.9 KBName:  IMG_0230.jpg
As pictured above, there were 3 rigid conduits coming into the old 1900 box that was holding up the old fan. Now, I bought a new fan rated box with saf-t-brace and there are only 2 openings on top of the box for the conduit.
I've tried an elbow connector to get one of the conduits to go into the side of the new box, but was unable to get enough slack for it to get into a working position.
It also appears that there isn't enough room on the box with the brace in the way to drill a new hole.
Any tips on what I should try next?
Are there any fan rated boxes out there with more than 2 cutouts on top for 1/2 rigid conduit?
Thanks.
Old 01-26-15, 09:48 AM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
What brand is that box? I would check a different mfg.can you squeeze that bracket a bit with a pair of Channel lock pliers?
Geo
Old 01-26-15, 09:58 AM
Received 4,146 Upvotes on 3,723 Posts
Unfortunately, I'm pretty sure all the bar type boxes only have the two knockouts.
In the link below is a sidemount box. It looks like you have a beam there. If you had attic access it would be even easier.
Westinghouse Sidemount Plus Fan Box, 2-1/8-Inch Deep
The box is available at the depot and the specs. state three knockouts.
Old 01-26-15, 01:10 PM
G
I checked the local depot and that side mount plus fan box only has one knockout on top and 2 horribly placed ones at awkward angles on the sides. The only fan rated box in the store with more than 2 knockouts on the top was a pancake box. After a few months of tinkering on and off and running into one problem after another, It's time to use the phone in my toolbox and let someone else fix it in what seems like 2 seconds.
Old 01-26-15, 01:19 PM
ray2047's Avatar
Do you have access from above? I wonder if your area allows FMC? If yes to both you might cut the conduit shorter and add FMC to the new box.
Old 01-26-15, 01:29 PM
Great idea Ray if the wires themselves are long enough.
Old 01-26-15, 02:45 PM
Geochurchi's Avatar
If you are going to change over why not just put a J box in the attic (exposed) and run Romex to the fan box?
Geo
Old 01-28-15, 09:43 PM
G
If I'm forced to go into the attic anyway, would something like this here provide the needed support? How sturdy would it be compared to a saf-t-brace that spreads between the joists?
Old 01-28-15, 10:54 PM
Yes sir. That is the box I left you in my link in post 3. It can be installed from down below and even easier from the attic.
Old 01-30-15, 02:39 PM
G
thanks for all the help, after a few more bumps and bruises in the attic, I finally got a proper fan box installed.
Now, I could use some input on the wiring of the fan and the wall switch. As pictured in my first post, coming from the ceiling conduit are 3 red wires, 3 white, 1 yellow, and 1 orange. I referenced this old post here, and got an idea of where to start, but my wall control switch is a bit different and I could use some help.
Here is how the old wall switch is connected (a casablanca 45e5)
And here is how the new one looks by itself (Hunter 27183)
As you can see the new switch has 4 wires including a ground coming from it, while the old switch only had 2.
Any tips would be greatly appreciated
Old 01-31-15, 10:13 AM
G
Figured it out. Everything is working now. Thanks for all the help.
Old 01-31-15, 10:36 AM
Certainly a lot of wires crammed in that switchbox.
Good job
Old 02-01-15, 05:36 PM
pcboss's Avatar
Received 206 Upvotes on 179 Posts
Probably a 1900 with a plaster ring.
