Square 8"x 8" recessed hallway light upgrade
I have a 8"x8" square recessed hallway light
that I'm looking to replace with a 15" round ceiling flush mount light.
I have 2 issues:
1) how do I mount the light when I only have a 4" bracket
2) Can I wire three 60W bulbs to this existing wiring?
I believe the wiring and existing light fixture to all be original from 1962
I have 2 issues:
1. I don't know what you mean by a "4" bracket" but most ceiling, surface mount fixtures attach to an electrical box. You may have to install blocking between your ceiling joists to support a box or they make boxes with metal brackets to attach to joists. Once you have a box then you'd just follow the installation instructions for your light which should be pretty easy.
2. The wattage and number of lights you can use will depend on the fixture you get. Your house's wiring should support 180w but the light fixture may not. Most lights like that that I have seen accommodate two bulbs either 60w or 100w depending on the fixture but I've not seen a three bulb one.
