Wire disconnected while replacing device
Old 02-26-15, 01:08 PM
While replacing the flip switch to our porch light the bottom black wire was disconnected from the back portion. Unsure of how to connect it again. Sure it's a simple answer just want to be careful. Thanks for all your help in advance!
Old 02-26-15, 01:19 PM
Received 4,152 Upvotes on 3,729 Posts
Welcome to the forums.
You were replacing a switch that should have had two wires connected to it.
How many wires were there on that switch and is it a one location (not 3w) switch ?
Old 02-26-15, 01:53 PM
N
Received 21 Upvotes on 18 Posts
Is that a timer in the box with the switch?
I'm on my phone, so a little tough to follow the wires.
Old 02-26-15, 02:59 PM
Thanks PJ,
There were two wires on the switch and it was a one location switch. (Not a third wire) Both the wires were connected to the switch but the bottom wire became disconnected to where it was connected inside.
Apologize for any terminology I use incorrectly.
Ahhhh... pictures.
Can you carefully pull the wires out of the box without disconnecting anything so that we can see the connections and post another picture.
I see 2) two conductor cables in that box. Are there any more ?
Old 02-26-15, 03:11 PM
More Photos
Let me know if this gives enough detail. I believe there are only 2.
Old 02-26-15, 03:20 PM
N
That third 14/2 and what looks like a timer/dimmer is going to make this interesting.
The wire in question is definitely from one of the maretts, but which one.
What is that dial control?
Old 02-26-15, 03:25 PM
N
Looking at the pictures, the dial controls the hot from the 14/2 on the left to the one on the right.
The switch is connected to the hot on the center cable, but I can't figure out where it should go.
Old 02-26-15, 03:51 PM
Success!
Figured it out. When I inspected the yellow wire but closer it basically popped without any resistance (I now remember the yellow marette being close to the switch when I was pulling out) so I clamped the three together and everything works great. Thanks for your help everyone! Will definitely be back and hope to help some others out in the future.
Old 02-26-15, 04:02 PM
Handyone's Avatar
You know where the wires go now, great job!
You can see the wire nut was unsecure. After you tighten the nut around wires, you should tug on each individual wire to ensure they are secure.
A wire should never be able to be pulled out from a wire nut.
