Lamp Ballasts Interchangeable?
Old 02-28-15, 02:03 PM
R
Hello from Toronto, Ontario, Canada
I have a defective 2 foot under cabinet T12 lamp in which the ballast is buzzing like crazy. The defective ballast is shown in the first photo.
I also have an unused 3 foot under cabinet T12 lamp which is fine. Can I switch the working ballast from the 3 foot lamp into the 2 footer lamp with no issues? The ballast from the 3 footer is shown in the second photo.
To confirm, I want to use the working ballast in the second picture, as a replacement for the defective ballast in the fist picture.
Having said all that it appears the pictures are UPSIDE down in my post, although the originals are not. It also seems they are being highly compressed so you can't read the details...GAH! What do you need to know to determine if these are interchangeable?
Name:  2 FOOT LAMP BALLAST.jpg
Name:  3 FOOT LAMP BALLASTxx.jpg
Thank you very much.
RivedaleDIY
Last edited by ray2047; 02-28-15 at 03:10 PM. Reason: Rotate, crop, and enlarge images.
Old 02-28-15, 05:28 PM
Received 4,152 Upvotes on 3,729 Posts
120TP (1) F14T12, (1) F15T12 or (1) F20T12
130TP (1) F30T12, (1) F34T12, (1) F40T12
Basically the same ballast but the 130TP has a higher strike voltage and higher lamp current rating. You may be able to swap them but the tube may not last as long.
