Replacing old switch with dimmer
Old 02-28-15, 02:46 PM
P
Ok so this would seem pretty basic but I am looking to replace a light switch with a dimmer switch.
Problem I have is that the dimmer switch has 2 black wires and a green wire coming out of it and the old switch has 3 black wires attached to it.
I am guessing the power is coming to the switch and then going to the light and going to another location as well.
How do I go about wiring this ?
Do I just have to connect 2 of the black wires to one of the wires from the switch ? And if so then how do I know which 2 ?
TIA
Old 02-28-15, 02:56 PM
ray2047's Avatar
The two connected to the same terminal of the switch. That is the screw and the quick connect at that screw.
Old 02-28-15, 03:55 PM
P
not sure if these pictures will help but still not sure which 2 black wires to connect together
Old 02-28-15, 04:02 PM
Received 4,101 Upvotes on 3,683 Posts
You will be combining the two circled black wires.
Single pole switch with one wire on screw and one in back stab.
