Ceiling fan light gone haywire
Old 03-04-15, 01:52 PM
D
I am new here,first post.I've searched everywhere for this scenario,with no luck.I have a Harbor Breeze cieling fan with 3 lights.The fan works,light does not.The sockets show 120v,screw a bulb into any of the 3 sockets and voltage drops to 0v on all 3.It calls for A15C bulbs,and that's what I have.Any ideas would be greatly appreciated.
Old 03-04-15, 02:27 PM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
How did you measure the voltage to know it went yo 0 volts?
Geo
Old 03-04-15, 02:30 PM
Received 1,287 Upvotes on 1,225 Posts
Has it worked in the past or always been this way?
Old 03-04-15, 02:34 PM
D
Actron multimeter red/hot on center tab of socket black/ground on outer rim/threads. Switch/pullcord on reads slightly above 120v,screw in a bulb to another socket,it goes to 0v.
Old 03-04-15, 02:38 PM
OK, so you're still reading on an empty socket but noticing the voltage on that socket drops to zero if a bulb is put into another socket - am I reading that correctly?
D
It has worked fine for about 2yrs.It was installed new 2yrs ago by me when I built the house.All the sudden all three bulbs quit working.
Old 03-04-15, 02:42 PM
D
stickshift,that is correct
Old 03-04-15, 05:54 PM
Received 4,148 Upvotes on 3,725 Posts
It sounds like the bulb dimmer circuitry has failed.
Old 03-05-15, 04:42 AM
Geochurchi's Avatar
Have you tried bypassing the switch?not much else in that circuit.
Geo
