Installing a ceiling fan (with light)
Old 03-10-15, 11:09 PM
Y
Ceiling fan has:
1 black wire
1 blue wire
1 white wire
Ceiling has 4 yellow wires bundled together, 4 white wires bundled together and 1 red wire. Could you please tell me which wire goes where? and could i add a ground wire to the fan fixture?
Old 03-10-15, 11:16 PM
Received 4,119 Upvotes on 3,699 Posts
Welcome to the forums.
It would appear your wiring is in conduit.
The yellow bundle is the always live connection.
The red would be a switched hot line.
The white bundle is the neutrals.
Do you want the switch to turn the light and fan on together ?
You can switch the light and use a pull chain for the fan.
Old 03-11-15, 07:25 AM
Y
Thanks for replying Pete
I only want the switch to turn on the light only if possible.
and the switch to turn the light on/off and use a pull chain for the fan.
Old 03-11-15, 08:20 AM
Y
so far I connected as follow..
1 black wire to 4 yellow wires
1 blue wire to 1 red wire
1 white wire to 4 white wires
and also added a small green wire from the white wires and screwed to the light fixture for ground, is that require?
Old 03-11-15, 08:48 AM
No.... don't connect any grounds to the white/neutral wires. You would need to connect a green wire from the metal box to the fan frame. Usually there is a hole tapped in the box for a green ground screw. If there is not.... use one of the fan bracket mounting screws.
Old 03-11-15, 09:44 AM
Y
ok. Thanks. I understand now what to do about the ground wire.
what about the other connections are they ok?
1 black wire to 4 yellow bundled wires
1 white wire to 4 white bundled wires
Old 03-11-15, 09:52 AM
Yes.... the other connections are good.
The light will be switched from the wall and the fan will use a pull chain.
Old 03-11-15, 10:18 AM
Y
Thanks again,
I will get back to you tomorrow as i got to leave now.
