Adding an additional light to a 3-way swtch
Old 03-12-15, 02:38 PM
I'm going to do my best to describe this without pictures because I'm hoping they won't be necessary.
I've got some stairs going down to the basement. Currently, there are two wall-mounted stair lights on the same 3-way switch. One switch is at the top of the stairs, and the other is at the bottom, obviously.
The problem is that these stair lights are pretty worthless in terms of illumination. I have a landing half-way down the stairs, but the builder never thought to put a recessed can light or wall sconce there. So, I want to add a wall sconce at the landing, and wire it into the same 3-way switch as the two stair lights.
One of the two stair lights is easily accessible via my basement utility room. So, rather than run my wall sconce wiring direct to one of the switches, I thought the easiest thing would be to run it straight down into the utility room and tie it in off the stair light. Can I do this?
Old 03-12-15, 03:23 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Yes. In fact with a 3-way it is the easiest way. Coming from a switch can be tricky.
Old 03-12-15, 03:44 PM
chandler's Avatar
Received 8 Votes on 7 Posts
Basically you don't add lighting from switches, but add lighting from lighting. As Ray says, it is very tricky to do with switches only.
Old 03-12-15, 05:07 PM
Great thanks. Now I just need to get up there and figure out how to daisy chain in the wire to the stair light. I think I might need to disassemble it.
Do I need 14/2 or 14/3 wire to connect the light?
Old 03-12-15, 05:53 PM
chandler's Avatar
You'll just need 14-2, since all you will be doing is connecting the black to black, white to white, and ground to ground, from light to light.
Old 03-12-15, 06:03 PM
Received 1,616 Votes on 1,488 Posts
Yes... you will need to remove the light to make splices in that box.
Old 03-12-15, 06:18 PM
ray2047's Avatar
14-3 assumes a 15 amp breaker.
Old 03-12-15, 07:42 PM
Great. 14/2 it is. My preference would be a recessed can light, but using a wall sconce is a lot easier because I don't have to cut any extra holes in the drywall to fish the wire up and over the corner where the wall meets the ceiling. Just the hole for the sconce itself should be sufficient for a straight shot down the wall into the basement utility room where I can splice into the stair light.
