Bathroom light fixtures cutting out/dimming
Old 04-08-15, 08:53 PM
W
Hope someone can lend some insight into this problem. I have 2 fixtures in a bathroom, one recessed and the other a surface mount. When they are turned on the recessed one goes out after about 35 seconds and the other dims shortly thereafter. I cannot think of where to start troubleshooting this. Any ideas?
Old 04-08-15, 09:18 PM
ray2047's Avatar
Are they on individual switches? If both on the same switch replace the switch. If separate switches and power comes in at the switch box replace all wire nuts at the switch box.
Old 04-09-15, 09:34 AM
pcboss's Avatar
Received 204 Upvotes on 178 Posts
If the switch does not solve the issue you need to check the connections at the fixtures.
