wiring lights
Old 04-24-15, 02:42 PM
wiring lights
Hello, ordered some lights and the instructions are from a different country. The wires are listed as
N-blue- Zero line
L-Brown - live line
Ground
Now I want to make sure I'm putting them up right. I would assume that the zero is neutral and the live is hot?
Old 04-24-15, 02:46 PM
chandler's Avatar
Received 2 Votes on 2 Posts
Yes the N is neutral. It may have ribs on the casing to tell you it is the neutral, maybe not. Are these designed for 220v. 50 Hz installation in Europe?
Old 04-24-15, 03:02 PM
No they are 110. They've LED flood lights. Made in China
Old 04-24-15, 03:30 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Are the casings metal. Is there no ground wire? Are you going to use them outside?
Old 04-24-15, 03:56 PM
Yes metal. And yes there is a ground wire. They will be mounted outside. These are commercial size flood lights.
