How would YOU install this ceiling fan?? - commercial space.
Old 05-06-15, 09:51 PM
1
Hey guys,
Wondering how someone more experienced than me would handle this:
My wife has a Yoga/Pilates studio and wants a ceiling fan installed in a room. (12' commercial exposed girders)
Its easy access to elec from 6 existing pot lights and open girder commercial ceiling.
Easy to tie into the existing pots for power, But they want to maintain the dimmer switch on the lighting.
Will a ceiling fan work on a regular dimmer?
Or should I pull power from an electric outlet on the wall? Run it somehow to a switch 3 bays over, and then feed it up to the fan, so it has its own source and control? What a pain in the arse... and close to impossible as they are mirrored walls
Thanks buds!
Old 05-06-15, 09:55 PM
1
I tried to post a picture but they said im not allowed
Old 05-06-15, 11:08 PM
Received 4,052 Upvotes on 3,635 Posts
You're probably trying to post too big a picture. Try to limit it to 100kb in size as the board does have a preset limit. Pics from phones are usually too big and need to be reduced.
You can't connect the fan to a regular dimmer. You will need to run a new line to it.
Old 05-07-15, 03:03 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
We'll wait on the pictures, but being in a commercial building, it may require conduit, just so you are aware.
Old 05-07-15, 05:50 AM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Is this a rental space?if so you better check with the landlord before you attempt any electrical work.
Just Saying!
Geo
