Replacing push button switch
Old 05-07-15, 07:19 AM
C
I'm replacing a push button dome light switch on my boat. It has two black wires.
The mfg set me a replacement switch that has a red, white, and black wire. What connects to what?
Thanks
Old 05-07-15, 07:45 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Sounds like the wrong switch but may work. Do you have a multimeter to test which wire give the desired result?
Old 05-07-15, 07:52 AM
C
I do have a multi meter - the kind that Harbor Freight gives away - but have never used it.
Old 05-07-15, 09:16 AM
ray2047's Avatar
Is this a momentary contact switch or one that stays in the on or off position?
Old 05-07-15, 11:54 AM
C
Push it once the light comes on push it again and the light goes off
Old 05-07-15, 12:05 PM
pcboss's Avatar
Received 87 Votes on 74 Posts
I would try connecting the black and red to the two blacks and cap the white. Did the switch come with a wiring diagram on the package?
Old 05-07-15, 12:27 PM
ray2047's Avatar
PCBoss' suggestion is how I would do it. I just tend to be over analytical with my advice sometimes.
Old 05-07-15, 03:40 PM
C
No diagram on package but here's more info:
The Digi-Key part# 527PB-ND
Product Sheet Here:
http://media.digikey.com/pdf/Data%20...40-4169-00.pdf
Old 05-07-15, 04:42 PM
Received 1,119 Votes on 1,039 Posts
The white wire on that switch is common. So use the white and black wires and cap the red one.
Old 05-08-15, 06:06 PM
C
Got it all wired and working
Thanks very much.
