Hunter Ceiling fan hums but doesn't start spinning
Old 05-19-15, 10:57 AM
D
Hello, I recently moved into a flat that has a newer Hunter ceiling fan (it's probably within 5 years old). When I moved in, it was winter but I tried the fan once and it worked. A month or two later when it started to get warm out I attempted to turn it on and nothing happened.
The fan is on one light switch (single switch) in the kitchen. The fan has lights as well, which work. When I flip the switch on and pull the fan chain I can hear the motor hum and cycle through the 3 speeds. The fan blades DO spin freely, regardless if power is on or off.
Originally, I thought the capacitor was blown so I purchased a new wiring harness from Hunter (part# K226602H03). The harness has new wires, switch, and capacitor on it. I installed it and everything stayed the same. The motor hums as I cycle through the speeds but the fans never start to turn.
If knowing the exact model of the fan would help, please let me know, I'm at work as I type this so I can update later if needed.
I am at a loss of what the problem could be. Any help would be GREATLY appreciated as my landlords are currently out of town and I would love some air flow in my warm flat!
Old 05-19-15, 12:15 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
You should never touch electric if you aren't licensed and don't own it. The liability is to great and then there is possible legal issues.
Buy a cheap box fan and set it in a window or better since fans don't coo buy a window A/C if your apartments electrical is adequate.
Old 05-19-15, 01:04 PM
D
The wiring harness is plug-n-play, I'm not splicing wires or anything. My landlord told me I could do it also.
Old 05-19-15, 01:22 PM
ray2047's Avatar
Which he will deny in court.
Probably a bad motor if you can't start it by spinning the blade but check the reversing switch first. Some times they vibrate to a half way point. If not the reversing switch best solution is a new fan. (Which becomes the landlords when you install it.)
