Dimming LED lights
Old 05-30-15, 04:52 PM
I
Dimming LED lights
I just installed recessed lighting in my kitchen with retrofit LED's. I goofed and bought standard dimmer switches. I went ahead and installed one and it seems to work fine. Is there any safety issue with using a standard dimmer with the LED's. They don't really dimm down very low... am wondering if an LED dimmer switch might have a larger range? I'd just return them, but it's an hour drive from here in the boonies!
Old 05-30-15, 04:56 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
You have to go to the boonies eventually, so I'd install a standard switch, pack up the dimmers and get good LED compatible dimmers for the lights. You'll be happier longer.
P
Temporarily Suspended
Most articles that I've seen recommend dimmers that are made for LEDs. Besides that, is there a ceiling fan involved?
Old 05-30-15, 05:07 PM
I
There is a fan on the same fuse, but different switch
Old 05-30-15, 05:46 PM
P
That's good. Can you exchange the dimmers through the mail instead of having to leave the boonies again?
Old 05-30-15, 06:20 PM
I
Well fortunately the wife leaves quite often on shopping expeditions, so getting them returned won't be too big a problem. Meanwhile, new ones will arrive at my doorstep in 2 days!
Old 05-31-15, 05:14 AM
P
You can't ask for more than that.
