Ceiling fan brace is to big to fit my joists?
Old 06-05-15, 03:11 PM
R
I just to down my light fixture box to install a ceiling fan box with a brace. When I inserted the brace to my amazement I found that the brace is to long. I am assuming when they build the house the joists was not properly spaced apart. Rats! I didn't think I had to measure the distance between the joists before I begun. Do the fan braces come any smaller? I can't seem to find any other than standard size. If finding one shorter option is out what can I do? Is there side mount fan boxes that I can use? or is there a way to make the brace fit? I got my living room in a mess. i thought this would be sort of a easy project. Lol. Thanks in advance.
Old 06-05-15, 03:38 PM
czizzi's Avatar
Received 14 Votes on 12 Posts
What is the measurement between ceiling joists? Is there a second story or is it attic space?
Old 06-05-15, 03:46 PM
P
Received 632 Votes on 584 Posts
Are you certain that your brace is not adjustable for length? Can you post a picture of yours or a link to it online?
Old 06-05-15, 03:47 PM
Received 1,118 Votes on 1,038 Posts
FBS-1423 from Arlington is all metal heavy duty side of beam fan mounting box. It can be seen on page 8 in the link below.
http://www.aifittings.com/products/p...TURE_BOXES.pdf
Old 06-05-15, 03:49 PM
R
roughly about 9 inches between the joists. There is another story above no attic.
I have researched a little and I am not the only one with the same problem.
they cut the bracket to size to make it fit. I am looking at that option now.
Old 06-05-15, 04:02 PM
Some of those expanding fan brackets can be cut. You'd have to make sure the end fitting came off and that the bar could be shortened.
Old 06-05-15, 04:48 PM
R
Thanks PJ max
I got the end fitting off I will cut it in the morning. I will let everyone know how it went.
Old 06-05-15, 06:36 PM
pcboss's Avatar
Received 87 Votes on 74 Posts
Sounds like you have TJI's on close centers. Take the old box down and stick a camera into the hole to see if you need to scab on a piece to the framing.
