craftmade ceiling fan winding wire color question
Received 0 Votes
The receiver unit on my craftmade fan is acting intermittanty, changing speeds and turnning the lights on in the middle of the night. switching dip switch settings changes nothing. I only use the low speed so I propose to wire it on/off only in the low speed setting. I have a soldering iron and the skills to desolder the caps.
So, The fan has four wires to the windings (brown, red orange & yellow). I checked continuity and determined that i have two separate windings without continuity between them.
brown & red = winding 1
orange & yellow = winding 2
Are these windings interchangable? Please set me straight if I'm wrong but I imagine that one of those winding will determine the direction by reversing polarity. The other will need to be wired with a cap I suppose but the speed is still a question for me.
Can someone please explain this or direct me to a wiring diagram?
Thanks
Thanks
Received 0 Votes
I've thought more about this and want to refine the question. I think the two windings are wired in parallel with one winding having a cap in series for phase delay.
Is that correct? Are the two windings interchangable or do I need to identify them.
Welcome to the forums.
Now you are saying the windings are in parallel.
That would mean you measure continuity between the two windings..... is that correct ?
You aren't going to find any wiring diagrams or schematics because they just weren't produced.
Received 0 Votes
No, I'm afraid my poorly writen second post has mislead you. I should have said that I think the two sets of windings SHOULD BE (not are) wired in series.
After I wrote that post, I tried an experiment. I wired the two windings in parallel with the capacitor (5uf) in series with one of the windings. It operated at a nice speed but had a bit of a hum. I then put the cap in series with the other winding (without changing the neutrals) and it ran backwards at a very high speed. I get that placing the phase shift on the other winding could make it run backwards but the high speed is a surprise. I'd expect more capacitance would be required for a faster speed.
Edit: Unless the winding resistance was different between the two windings. That might acount for the difference in speed.
