Dimmer switch in/out question?
Old 06-21-15, 01:44 PM
E
Received 5 Upvotes on 5 Posts
So I have this dimmer switch with an almost invisible drawing of circles with lines. Which one goes to the mains voltage and which goes to the lamp?
Old 06-21-15, 01:52 PM
Received 4,101 Upvotes on 3,683 Posts
We can see even less in the pictures than you can see.
Be careful.... that looks like a 12vdc dimmer.
If that is indeed a line voltage dimmer.... there should be no polarity.
Old 06-21-15, 02:08 PM
E
Try this? https://www.dropbox.com/s/rntk0mepwg...%20pm.jpg?dl=0
It says 3a 250v i asumme thats AC
Old 06-21-15, 02:12 PM
If it says 3A 250v then it should be ok. There doesn't appear to be a polarity to the hookup.
Old 06-21-15, 02:34 PM
E
Thanks! Either polarity didn't matter or I got it on the first try. Works
Old 06-21-15, 05:06 PM
E
Is it normal that I'm loosing 5% of voltage? From the the hot side to the box is 219 and from the dimmed side to the box is 207 even on full.
Old 06-21-15, 10:21 PM
It is possible that the dimmer does not pass 100% of the voltage thru.
Think of of it as a bulb saver. That slightly lower voltage will extend lamp life.
Most dimmers run warm in use.... that is a loss of voltage there.
Old 06-22-15, 05:51 AM
E
Thanks for the info. I just realized that I need to yank it anyway since it's rates for 300w and I've got 6x50 now and want some more.
Long project, Murphy's law had some last minute fun with me and all but 1 of the first set of holes I marked ended up being under rebar
Thanks again for all the help from the forum!
Here's a pic.
<img src="https://lh3.googleusercontent.com/-u8YvTkRQ_IA/VYgEi3iYZpI/AAAAAAAAEik/vh9TfUkOLqI/s1024-no/IMG_9531.JPG" width="1024" height="768"/>
