Where can I find a replacement light bulb for this R12?
Hello all,
I need to replace this light bulb under my fan. It is too bright and uses too much energy. However, I cannot find the model number and the only information I can find is as follows:
westinghouse
120V 150W
China R12
Thank you
westinghouse
120V 150W
China R12
Thank you
What wattage where you hoping to get ?
I see 75 and 100 watt but not much smaller.
Triangle-Bulbs-T10401-2-Candelabra-Halogen
Philips 75-Watt Halogen T4 Mini-Candelabra Light Bulb-415562 - The Home Depot
Hello,
Thank you for the search and I will keep those bulbs for record.
The ideal bulb I was looking for is LED or Fluorescent and should be less than 40W.
Question> Is it true that my bulb is T4 base?
Thank you again!
Thank you again!
A selection of bulbs at the Depot.
Candelabra - LED Light Bulbs - Light Bulbs - The Home Depot
Keep in mind.... an LED bulb may not dim in your fan regardless of the claim on the bulb.
This should work but it not be cheap,
LED Tube Light Bulb, T4 Size, Only 0.9 Watts Replaces 7W to 10W
Geo
Geo
