Whole House Fan Timer
Old 06-26-15, 07:46 AM
B
I just replaced the motor on my belt drive whole house fan with a 5KCP39HGAA06B5 Its 120 Volt, 2 speed. The previous motor was also two speed with a rotary switch controlling it. The low speed never seemed any lower than the high speed, although the sound it made changed a bit. All that said, this one also seems to not make a difference when turned to low speed either.
All that being said, here is my question. I am considering replacing the rotary switch with a timer similar to one I saw on a recent post here. The rotary switch uses the red wire to control the low (non existant) speed. As the times will not have that option and i do no want to add the switch inline before the rotary switch, can I just remove the rotary and cap off the red wire as I don't need the low speed?
Old 06-26-15, 08:42 AM
G
Received 2 Upvotes on 2 Posts
In a word, yes. .
Old 06-26-15, 10:00 AM
B
Awesome. I was thinking that would be the case. Thank You!! Bill
