Recessed lighting above couch
Old 06-28-15, 07:39 PM
H
Hello, we are finishing our basement and I've already drywalled, painted, etc. When I installed my recessed lighting, I wanted some lights over the couch because we dropped the ceiling down for a heating duct. The drop ceiling is drywalled and about 6ft tall above the couch. I installed 4" HALO recessed cans above the couch. These lights are linked to 5 other 6" cans on a dimmer.
When I did this, I'll admit I didn't place the cans far enough away from the seating area so the lights will be almost over your head when sitting down. I was limited because of the ductwork. Dumb I know, but nothing I can change now.
That's the background information. Now I am to light bulbs. I bought a 4" led light and trim kit that would match the rest of my 6" recessed lighting. When I flipped the switch on, these lights are way too bright. So I bought Par16 350 lumen lights. These are much better but still a bit bright.
Is there anything I can put in these cans that will give off a very low light and still be dimmable? The couch is in my home theater area and I would like to dim for movies, etc.
I've attached a picture.
Thanks for the help!
Old 06-28-15, 07:58 PM
Received 3,422 Upvotes on 3,068 Posts
It's an art when you install recessed lighting. You need to be physic and fortune teller all in one. They're never put where you want them. I'm running into ductwork in a kitchen re-do I'm working on for a customer.
You need these 4" lights to dim the same way the 6" lights do ?
What are you using for bulbs in the 6" cans ?
Old 06-28-15, 08:08 PM
H
Yes they will HAVE to dim like the 6" on that side of the room because they are all wired together.
However, I guess if I got extremely low lumen lights, they wouldn't have to necessarily dim.
In the current 6" cans, I have BR30 down lights by TCP.
Thanks!
Old 06-28-15, 08:19 PM
Having the regular incandescents on the circuit will make the dimmer operate smoothly with respect to the LED bulbs. LED bulbs don't always dim well.
I can't really offer you a solution other than trying different bulbs. There are just too many out there to keep up with.
Old 06-29-15, 06:56 AM
F
Physic, what's a physic? Do you perhaps mean a psychic?
Old 06-29-15, 08:33 AM
C
Received 109 Upvotes on 88 Posts
I knew you were going to say that.....
