Safe to screw into wall end cap
Old 07-01-15, 06:39 PM
A
Is there ever wiring behind a living room wall end cap? I want to mount a small plug in lamp there, but don't want to accidentally hit any wires. There is a switch a couple feet away from it on the same wall....
Old 07-01-15, 07:14 PM
ray2047's Avatar
Not sure what you mean by end cap. Please post a picture. http://www.doityourself.com/forum/li...rt-images.html
Old 07-01-15, 07:24 PM
A
I can get a pic tmr if necessary, but i just mean the end of the living room wall where it has a square end with metal just under the surface. does that make sense lol
Old 07-01-15, 08:33 PM
ray2047's Avatar
Whats under the metal? Is it a wood stud or do you mean you have a steel stud at the end. Bottom line don't use screws longer than the thickness of whats at the end if it is a wood stud. Metal stud could have a cable in it
Old 07-02-15, 06:15 AM
A
There is the pic. I want to install something on the square end facing out. Is it called a wall end? Anyway, I see the light switch right around the corner. I'm only using 1 or 2 inch screws. Could there be any wiring in that wall end area? I would imagine the switch wiring runs vertically up from the switch, or can it be running out horizontally? This is nyc so anything is possible.
