Bulb voltage for under-cabinet lighting?
Old 07-03-15, 08:22 PM
Apologies if this is a dumb question. I just bought a home and it has under-cabinet puck lights. They seem to be wired to a standard wall switch. The bulbs installed are bi-pin halogen, and say "4g 12v 20w".
They seem to work fine but I was under the impression I would need 110/120v AC bulbs for lights installed on home wiring. (I thought 12v bulbs were for RVs, etc.) Is there anything wrong/dangerous with continuing to use the 12v bulbs on a 120v household circuit?
I'd like to try replacing these with LED bulbs (the halogens get VERY hot), but can't seem to find any G4 bulbs that are 120v AC - they are all 12v. Can I use these, since there are currently 12v halogens installed that seem to work?
Old 07-03-15, 10:57 PM
ray2047's Avatar
12 volts is correct for most under cabinet lights.
The lights are not on a 120 volt circuit. They are on a 12 volt transformer on a 120 volt circuit. Depending on the transformer LEDs may work but with reduced life span. Best to replace the transformer with an LED driver.
