Wiring a 3 way switch
Old 08-06-15, 11:31 AM
N
Just want to say thank you in advance, I've gotten a lot of helpful advice from you guys. Is my wiring correct? In my living room, I have 6 recessed cans all going on the same 3 way. They are in two rows of 3 (to help you visualize). To make less confusing ill use the abbreviation L1R1... meaning light 1 row 1, etc
I have 12-2 power coming in at Switch1.
Then ran 12-3 from S1 to L1R1. From L1R1 ran 12-3 to L1R2. Then 12-3 from L1R2 to S2.
Ran 12-2 between each light in the same rows.
In other words...
12-2(power)----S1----(12-3)----L1R1----(12-3)----L1R2----(12-3)---S2.
L1R1----(12-2)----L2R1----(12-2)----L3R1.
L1R2----(12-2)----L2R2----(12-2)----L3R2.
Also used 12 wire for lights because my father in law had a ton of extra wire.
Old 08-06-15, 11:49 AM
ray2047's Avatar
Do you have a 12-3 between the switches in addition to the 12-3 to the lights?
Old 08-06-15, 11:56 AM
N
No. From reading other post, I thought thats what I would need.
Old 08-06-15, 12:02 PM
N
If I add that 12-3 between the switches, then the wires between each light can be 12-2? So the 12-3 currently between the 1st lights in each row is unnecessary?
ray2047's Avatar
You need two wires for travelers between the switches. What are you using for travelers.
Old 08-06-15, 12:10 PM
N
Based on what I read, I didn't think I needed 12-3 between the lights.
Old 08-06-15, 12:15 PM
N
Old 08-06-15, 12:18 PM
ray2047's Avatar
Sorry I miswrote.
What is the purpose of each wire of the 12-3?
Old 08-06-15, 12:34 PM
N
Two are travelers with one being hot, one neutral, and ground? Correct
Old 08-08-15, 04:06 PM
A
Received 288 Upvotes on 263 Posts
The clearest way to wire this is to run a 12-3 from one switch directly to the other switch. If the best route goes to the light fixtures, then run this cable around the outsides of the #1 light fixtures.
Then you will not need 12-3 among the lights themselves.
Travelers are both considered hot. The third wire in the 12-3 traveler cable is a feed or a return depending on its sequence in the out-and-back path to the far switch.
Old 08-08-15, 04:48 PM
ray2047's Avatar
No. Not even close really.
Simplest way:
This is a way that meets NEC 2011 code:
