Attic exhaust fan wobbling/vibrating
Old 08-07-15, 02:15 PM
B
Received 5 Votes on 2 Posts
I replaced the dead motor in my parent's attic fan. I didn't realize the fan blade was attached via a set screw to the motor so I moved the mounting brackets around to get both the motor and blade out.
After replacing/reinstalling the motor and blade there is a bit of vibration that wasn't there prior to removal. I'm guessing either I tweaked the blade so it is off balance and or I tweaking the mounting brackets - that hold the motor, so it's not on center. After doing some measurements, the motor and blade seem to be proportionately installed - same distance from blade edge to the vent housing edge, and same distance from the motor casing to the vent housing.
I may need to go onto the roof and tighten the screws that hold the motor mounting brackets to the vent housing.
The vent is like the one pictured. Standing one the back apartment roof, I could clearly see the vent hood and that it is vibrating a bit. My uncle installed this some years ago and I'm wondering if he did a good job, that perhaps the whole vent housing isn't attached to the roof correctly.
Any thoughts/suggestions? Thanks.
[ATTACH=CONFIG]54322[/ATTACH]
Old 08-07-15, 03:42 PM
Received 2,811 Votes on 2,543 Posts
I'm guessing you replaced the motor with the same speed.
Vibration is usually caused by a bent blade or blades.
