How to find a short without a tripped breaker?
Received 0 Votes
Hi,
I tried to replace a broken power switch. I was supposed to turn off the specific breaker first. But that switch does not have a individual breaker. If I want to cut the power, I will have to turn off the main power source, which means every electrical devices will be dead. I don't want to do that.
So I took the risk doing it with the power on, "bang" and some sparks: the power was off and so were a few lights and ventilation fan.
My question is how to trace the short in the situation where no breaker connected.
Thanks in advance.
z_johnq
Thanks in advance.
z_johnq
Ok... so after you shorted the switch what happened ? Did a breaker trip ?
Or are you saying nothing tripped and that part of the circuit is now dead?
Every device in the house MUST be on an individual breaker or you risk a fire hazard from overloaded/shorted wiring.
Received 0 Votes
Thanks guys. Yes. I thought a breaker should get tripped after the "bang" but it was not as I looked at the power panel. I agree with PJMax that Every device in the house MUST be on an individual breaker or you risk a fire hazard... but it's not what I got.
Can a breaker get loosed? I'll test it and let you know. Thanks again.
Received 0 Votes
Yes, I own the house; it's not new no more, was built in 1980.
Thanks for the reminder that there might be another subpanel that I overlooked.
Btw, I checked and there is no loose breaker. None of them got tripped.
