6" can replacement in vaulted ceiling
Old 09-07-15, 09:03 AM
A
I need to replace the 7 6" cans in the vaulted ceiling in my kitchen.. The lights are approx 20 years old and blink after being on for 5 or ten minutes.. There is no crawl space..
Can these be replaced without cutting into the drywall??
Note that I am in Arizona and that this happens year round but is much worse in the summer..
Old 09-07-15, 09:23 AM
XSleeper's Avatar
Received 1,960 Upvotes on 1,757 Posts
Only if they are remodel cans.
Old 09-07-15, 09:33 AM
Tolyn Ironhand's Avatar
Received 907 Upvotes on 765 Posts
Welcome to the forums!
Can light that are blinking on and off are doing so because they are overheating, your quote above also tells me that they are overheating. Likely the lamps (bulbs) you have installed are too high of wattage for the can/trim that is installed. Changing out the cans will not help the issue, and would be waste of time and money. If you really do have an issue with the thermal overload it can be serviced from below the ceiling.
First tell us what type (wattage, size, etc) of lamp you have installed and if they are on a dimmer. Have you recently had any insulation added?
This will likely be as easy as changing the light bulbs.
Old 09-07-15, 11:24 AM
A
Lights are not on a dimmer. I have FEIT conserve enrgy bulbs. They say they are BR30 LED 2, 13w 750 lumens..
Old 09-08-15, 03:41 AM
Remove the trim and bulb and look inside the can for a label. See if the label is marked "IC rated" or Approved for contact with insulation. Of you don't see anything post the model number of the can.
Do the bulbs blink, or do they turn off for a couple of minutes then come back on?
Old 09-08-15, 05:00 AM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Did this just start when you changed the bulbs?
Geo
Old 09-08-15, 06:41 AM
A
On some of the cans the bulbs can be off for 1-3 minutes, others for 25 seconds to a minute. Its been a problem for a few years but has gotten worse over the past year...
Old 09-08-15, 07:03 PM
That is almost for sure overheating, but with LED bulbs they shouldn't get that hot.
Did you see if they are IC rated cans?
When they turn off or on can you hear a small "click"?
Old 09-16-15, 08:01 AM
A
Occasionally I hear clicking. Not sure if they are IC rated.
