Tie Switches Together
Old 09-14-15, 10:06 AM
I am looking for a contraption to tie two light switches together. I want to force my children to turn on the exhaust fan when they turn on the light - without re-wiring the switch itself. Similar to what you'd see in an electrical panel. Have you heard of such a thing? If so, what is it called? I can rig something up, but would rather not have it look as though I rigged something up.
Old 09-14-15, 10:16 AM
Received 330 Votes on 308 Posts
Welcome to the forums.
In a panel it's called a circuit breaker tie handle. I've never seen one for switches before.
You may be forced to design your own.
Old 09-14-15, 10:45 AM
Received 46 Votes on 43 Posts
I know you said it's not what you want but I would re-wire the switch to turn on both.
Old 09-16-15, 07:20 PM
Received 15 Votes on 15 Posts
A home fashioned switch toggle tie you are thinking of will probably not withstand regular use by children.
If the fan and light were not powered by the same cable coming into the switch box then you could use one double pole switch to control both light and fan and leave an original switch connected to nothing in the other position.
Old 09-16-15, 07:38 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Or if a Decor plate a blank insert.
