DIY Lamp with Backlight Votlmeter
Old 09-26-15, 08:57 AM
D
Members location is Bulgaria.
Hi All,
I recently completed my second steam-punk pipe lamp with a water valve controlled dimmer and a functioning voltmeter. However, being the restless type I came across an analog voltmeter with a backlight, which would be a great addition to the project. My issue is how to connect the LED light of the voltmeter to my existing circuit? I'm an amateur when it comes to electronics...
The setup currently:
220v input, through a dimmer switch connected in series (on the live wire), then the current voltmeter connected in parallel and a light bulb.
The LED for the backlight voltmeter I found has these specs:
Led Lamp voltage : 6-12VAC/DC
need the resistor :10-50Ω 1/4W ,if VAC 10-12V
Due to the specifics of my setup my only choice is to connect the LED to the existing 220v circuit. Will that be possible? Can I perhaps use THIS driver?
Thanks for the help!
Old 09-26-15, 06:24 PM
C
Received 183 Upvotes on 150 Posts
The driver you link to should work. You may still need the series resistor; there isn't enough info about the driver to know for sure. Putting the resistor in series with the output of the driver would be safest to test it out so you don't overdrive and damage the LED. There are many other ways to do this, but none of them will be as cheap as that driver.
Cool lamp by the way!
Old 09-26-15, 11:55 PM
D
Thanks for the reply!
Im not necessary looking for the cheapest way, rather the most compact and easiest in terms of connecting Is it a problem that current flowing to the driver will be 0-220v since its coming from the dimmer?
Old 09-27-15, 05:45 AM
C
One can't tell from the info provided what the driver will do when the input voltage drops below 180 volts. Most likely it will just stop working, which means the backlight will go off when the dimmer is set low. This would be true for most other solutions (such as a step down transformer, or a 220 to 12VDC power supply) as well. The only practical way to have the backlight work regardless of dimmer setting is to not power it from the dimmer, but just power it always from 220 by connecting it before the dimmer. Of course, that means it won't turn off when the dimmer switch is off.
Old 09-27-15, 07:16 AM
D
Thanks, that sounds good actually - I don't mind having the light switch after 180v only. Ok, seems the only thing left is to order this thing and test it Will post results! Thanks again.
