Exhaust Fans Not Working (along with lamp)
Old 09-27-15, 11:04 AM
Hi,
Suddenly, my two exhaust fans (with lamp) in two different bathrooms on 2nd floor stopped suddenly working.
I checked the tripper and looks fine on the panel in the basement. Nothing seems to help. I opened up the fixture and checked the outlet underneath exhaust fan assembly. I don't see any voltage. So somehow no supply voltage coming to exhaust fan assembly.
Any ideas what the problem might be?
Appreciate your help in advance.
Old 09-27-15, 11:09 AM
Received 338 Votes on 316 Posts
Welcome to the forums.
It is possible that those units are connected to a GFI receptacle or circuit.
Have you checked all GFI receptacles ?
Old 09-27-15, 11:54 AM
I checked the one in one of the bathrooms where exhaust fan is not working. I haven't checked all GIF using "test" and "reset" button. There is one in kitchen.
Do you think that it might be the problem?
I also reset all breakers in the basement for 2 nd floor where 2 out of 3 exhaust fans are not working.
Old 09-27-15, 01:22 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
The GFCI could be anywhere, even a garage or outside or hidden behind something that hasn't been moved in years.
Do you mean breaker?
Likely source of power is either at the fan or the switch for the fan not a receptacle though the power might originate there. The places to test are the switch and the fan. You can not check for power with a non contact tester. You will need a multimeter, preferably analog (or a neon test light or a solenoid tester).
Tell us all the wires and how they are connected at the switch and we will go from there. In addition a picture of the switch pulled out showing all the connections and wires may help. Do not disconnect any wires yet. http://www.doityourself.com/forum/li...rt-images.html
