Low voltage transformer - switch incandescent to LED lights?
Old 10-23-15, 01:57 PM
C
I have an older set of low voltage incandescent garden lights and was wondering if I could switch the fixtures to LED ones? I would like to know if I can use the old transformer and wiring with the new lights??
Thanks in advance....
Old 10-23-15, 02:39 PM
ray2047's Avatar
Look for a retrofit LED module for low voltage landscape lights (Malibu). Example: http://www.amazon.com/replacement-vo...=indifash06-20
Old 10-23-15, 02:55 PM
C
Old 10-23-15, 04:41 PM
ray2047's Avatar
You have AC those may be DC only.
Old 10-26-15, 08:43 AM
C
Thanks for all the info about the bulbs. I read somewhere online that these lights can have issues if the wattage used is not at least half of what the transformer is rated for?? Do you know if that issue would be the same for LED bulbs? I think the wattage will go from 30W to like 6W if I convert to LED and my transformer is rated for 42W.
Old 10-26-15, 11:17 AM
Received 3,747 Upvotes on 3,360 Posts
The LED replacements are not susceptible to slightly higher voltages like the incandescents are.
Old 10-26-15, 04:42 PM
C
Awesome - thanks for the info
