Light spreading tape?
Old 10-25-15, 04:43 PM
I'm going to buy those cheap angel eyes to my car: 4 x Multi Color RGB LED Halo Rings Light 90mm 5050 Super Bright Angel Eyes | eBay
But I absolutely HATE how the lights in the ring appears to be dotted. I would like a very clean ring of light instead of a dotted ring. So is there any tape that I could put on the led ring that is spreading the light so it appears not to be dotted?
I want it to look like this: http://g02.a.alicdn.com/kf/UT88cCJXb...gXXagOFbXD.jpg
Old 10-26-15, 12:14 AM
Received 3,887 Upvotes on 3,484 Posts
Welcome to the forums.
I don't think there is anything you do to make LED lights look like CCFL (cold cathode fluorescent lamp) type lights and be effective. You could possibly cut a ring out of translucent plexiglass but it would reduce the light level and the effect.
Old 10-26-15, 03:14 AM
Thanks.
Are you sure it's not possible to make it look good with LED's covered with something, such as translucent plexiglass?
Those are LED and they look good: RGB Angel Eyes Cotton Light LED Light DRL Turn Light For Car Headlights One set-in Angel Eyes from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
Old 10-26-15, 05:12 AM
T
Received 190 Upvotes on 166 Posts
Using a translucent cover will help, but each LED will still present a brighter spot. The problem will be finding one the right shape and size; check where you bought the lights.
Old 10-26-15, 05:15 AM
At what range do you think the brighter spots all fuses together and looks more clean if I use a translucent cover? Are we talking about 1 m or 10 m?
Old 10-26-15, 02:35 PM
You won't know until you try it. There is no way we could tell you ahead of time.
