Can I Add a Lite Kit to a 20 yr old Casablanca?
Old 11-18-15, 03:02 PM
H
Received 8 Upvotes on 7 Posts
The bottom cap on my old fan is 4" diameter and does have 2 lite wire inside it.
The internet info that I found is pretty slim on details. Anyone out there tried this?
Old 11-18-15, 03:26 PM
Received 4,101 Upvotes on 3,683 Posts
You may have to take the cap off and with you when you go light shopping.
If you had an exact model it could be looked up.
Old 11-19-15, 01:35 PM
H
Excellent Advice
It is almost too easy. If anyone's bottom cap has a 3/8" hole in the center, remove the cap and screw in a nipple to attach the universal lite kit. $20 at the orange store. Install time less than 1/2 hr.
Old 11-19-15, 01:47 PM
ray2047's Avatar
And if no hole grab your drill. Nuts can be used on an unthreaded hole.
