How to find model# of a Timer Switch?
Old 11-28-15, 08:56 PM
Hello:
My Timer Switch stopped working. Neither manual pressing the button nor scheduled switch work - it doesn't turn on the lights it's supposed to control.
The display is working, and displaying a flashing "batt", which I presume to be an error code. What is it? If it means "battery", then I can't see where the battery would go in this device.
Can someone tell me how to find out the name and model # of this thing to download user guide and find out what the error code is? Nothing printed on the side of this thing looks like a model#.
Or should I just forget it and replace it with a new one? Any recommendation on which one would be the most flexible and programmable?
Old 11-28-15, 10:39 PM
Received 331 Votes on 309 Posts
That looks like an older battery operated Intermatic timer. There is a battery behind the lower door. My recommendation... send it packing. When they get older the battery socket makes poor contact and the thing operates intermittently as well as loses its program. I had four at one time... they're all gone now.
Defiant 49814 timer from Home Depot. This timer needs a neutral connection. It doesn't use batteries. It has daylight savings and auto time change to match the seasons based on time zone. It has a switching relay so it can control ANY load under 20A. For $25.... a choice.
Defiant 20-Amp 7-Day 7-Event In-Wall Digital Timer-49814 - The Home Depot
Old 11-29-15, 05:27 AM
Geochurchi's Avatar
Received 15 Votes on 15 Posts
check this link out ,it appears the battery is under that other door.
http://www.intermatic.com/~/media/in...structions.pdf
Old 11-29-15, 08:46 AM
I can't read the model number, but the manufacturer is Intermatic Inc. Suggest you go to their website and match one of their digital electronic models. The manuals should also be available.
Old 11-29-15, 10:32 AM
chandler's Avatar
Received 2 Votes on 2 Posts
Pete, will the timer you listed require a neutral? Just thinkin' out loud.
Old 11-29-15, 10:42 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Larry asked: Pete, will the timer you listed require a neutral?
Pete wrote: This timer needs a neutral connection.
Old 11-29-15, 10:47 AM
chandler's Avatar
Capital "Duh"..............................
Old 11-29-15, 10:32 PM
Wow, thanks!
Thank you all soo much! I've ordered a replacement and the schematic from the Easy-Set Guide will help me wire the replacement up really quickly!
I didn't really expect anyone to recognize this thing. Truly - ask, and it shall be given you
