Lowering a ceiling
Old 12-02-15, 12:04 PM
K
Lowering a ceiling
I have a 3 season room with a ceiling fan securely mounted to the roof joists. The room currently has a plywood ceiling. I am adding a 2 inch layer of rigid foam, 3/4 strapping, and 1/2 inch sheetrock --- lowering the existing ceiling by 3.25". My question is whether I have to lower the fan or can I just leave the original mounting hardware in place and install a new canopy to the new sheetrock ceiling. I have plenty of clearance for the blades --- it's a 10 foot ceiling and the fan hangs 20 inches down.
Old 12-02-15, 12:16 PM
K
Received 4 Upvotes on 4 Posts
Remove the existing electrical box and build it down the thickness of the new ceiling with solid blocking behind it.
Old 12-02-15, 02:08 PM
ray2047's Avatar
Is the existing box fan rated?
Old 12-04-15, 05:32 AM
pcboss's Avatar
Received 200 Upvotes on 175 Posts
The box needs to be recessed no more than 1/4" from the face of the drywall. You need to move the box down.
