Replacing light fixture in old house bathroom.
Old 12-03-15, 03:06 PM
I
I'm replacing a wall light fixture in the bathroom of my 1955 home.
The fixture has one black wire, one white wire, and a bare copper ground wire.
There is one black wire and one white wire coming from surface mounted wiring that leads back to an electrical wall outlet on the same wall.
The house box has one black wire and one red wire. No white, and no ground wire, and no screw.
There is a green screw on the new fixture back plate.
I can't figure out what is supposed to connect to what. Help, please?
Old 12-03-15, 04:16 PM
pcboss's Avatar
Received 204 Upvotes on 178 Posts
What wires was the old fixture connected to?
Old 12-03-15, 05:23 PM
I
I don't know. I'm not the one who took the old one off, and they don't remember, other than the white from the outlet was connected to the white of the fixture, and they thought that both the red and black from the house box were connected in conjunction with something else. That's the best I got.
Old 12-03-15, 05:37 PM
ray2047's Avatar
Please post pictures of all your wiring. http://www.doityourself.com/forum/li...rt-images.html
Old 12-03-15, 06:12 PM
I
Wires at bottom of photo are those coming from the outlet on the wall Name:  ELECTRIC BOX.jpg
Old 12-03-15, 06:43 PM
ray2047's Avatar
Does the receptacle still have power? Do you get ~120v measuring between the black and white from the receptacle with a multimeter. Was the light controlled by a switch?
Note: Be prepared for criticism of the installation. If the answers are yes to the preceding questions think I know how it was connected but it is not code compliant.
Old 12-03-15, 07:08 PM
I
I don't own any kind of meters. The outlet is not currently working. If I recall, the light and one of the receptacles were controlled by the switch. The outlet is a GFCI outlet. When checking just now I pushed the test button, and now the reset button won't go back down...
but that was AFTER checking for power.
Old 12-03-15, 07:47 PM
ray2047's Avatar
Show us a picture of the wiring at the light.
Old 12-03-15, 08:10 PM
I
Old light had four bulbs Name:  old light.jpg
New light has 3 bulbs Name:  new light.jpg
GFCI Name:  GFCI.jpg
